Fuel gauge and light
Couple of questions, probably unrelated to each other.
1. Does the fuel sending unit control both the gauge and light? My gauge has not been working, but the light came on yesterday, and wont go out. Yup, put gas in it.
2. Still hard to start cold, but does finally. Then just dies after several minutes, that's it, right now, dead. No rhyme or reason. Idling about 750 when it goes. Fuel relay is currently bypassed, may have ECU issue.
Whatever light you can shed---
Phil
Phil
The sender controls both, but the terminals on the sender are separate, one for the gauge, one for the light, one earth.
Try to diagnose the condition a bit more. Are you sure there is fuel at the rail when it dies? Have you tested for spark when it dies? Have you changed the fuel filter and looked inside the sump tank under the battery for blockages? Does it restart after standing for a bit - if so a fuel problem is a distinct possibility;
greg
Greg
greg
Greg
Greg,
I have had the sending unit out of the car and tried to ohm it, but really couldn't figure out how. It seems to work, but was a real mess after sitting for 8 years. The float did not appear to be damaged, but I have read something about changing it anyway. Gauge has not been working, but the light did not go out after gassing. May be in line for a new one.
I have pulled and cleaned the sump, and inspected main tank, no debris. I have a fuel pressure tester, and plan on getting a brass T to install in line with an injector and test pressures while running. I should have added I have been chasing idle. I will get it smoothed out, then it just changes speed on its own, both up and down. New coils, plugs and wires. Fuel pump is really loud while running.
Greg,
The fuel gauge sender sounds as if it is shot. You can test the gauge by briefly earthing the sender wire while someone watches the gauge (ignition on)., and the light going out by pulling the light connector off the sender. As grant mentioned on another recent post, undoing the fuel feed line the the A bank pressure regulator (US passenger side of the engine) and seeing what the flow is like, is a good basic test. It should roar out.
Greg
Thanks Greg,
I pulled the black wire and the light went out. So then I was trying to figure out which of the other two to touch to ground to not hurt anything, so I pulled one of the others and the light went out. So I grounded the other, with wife's help, and the gauge did work. Sending unit looked like crap when I first cleaned the tanks, so no surprise there.
Got a new fuel filter, will change tomorrow. Kinda ashamed to admit this, but I changed the fuel filter after getting the car, BEFORE I pulled and cleaned the crap out of the sump. Hopefully some of my idle chase has to do with a clogged filter. If not, I will replace the pump also.
Phil
Phil
OkieTim
09-08-2015 04:48 PM
