Fuel gauge & low fuel indicator
As regards figuring out fuel level, I have no proper idea, BUT I would pull out that spare tire, and the trunk back board. There is then the access to the sender... Get lots of rags, soaked in water.... use the brass drift (see the post further up this thread)..... and GENTLY start to remove the securing ring. The gasket might be tight, and the sender may not be loose immediately and could need some encouragement. IF fuel starts to seep out get rid of the cigar, and re-secure the ring.
At least you will know that you have c. 2/3rds to 3/4s fuel.
Others may have a more sophisticated method. I will defer to them !!!
you can also rap the tank with your knuckle and hear where the fuel level is. It will ring above the fuel line and be dull below.
Greg in France (04-07-2018)
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
