Fuel leak
Fuel leak
The car has been running and driving beautifully. Saturday after a 4 hour blast, pulled into the garage and could smell fuel. It's coming from the clamped hose areas around the fuel line pressure tee. You can probably guess why; I gather the PO didn't think it necessary to flare the cut ends or use a compression fitting or, well, anything. No idea why it's lasted this long and I should have caught it when I was getting the engine sorted...
Anyway, what's the best way to deal with this? I'd like to keep the tee in place actually so would a compression fitting with hose barbs on the cut ends and new 5/16" hose do it? Do I actually need the clamps at all if it's barbs all around? Or different clamp type?
Grateful for any input, thanks
Anyway, what's the best way to deal with this? I'd like to keep the tee in place actually so would a compression fitting with hose barbs on the cut ends and new 5/16" hose do it? Do I actually need the clamps at all if it's barbs all around? Or different clamp type?6
The following 2 users liked this post by rgp:
Greg in France (03-16-2021),
jag-reflex (03-15-2021)
the fuel return pipe to the rail is missing , as above, a right bodge, probably isn't even fuel rated pipe ? looks like they added a high point bleed nipple for some reason ?
dont drive until you have sorted, otherwise it could end in a ball of flames...
BB
BB
yes, I understand completely. I've checked into oem replacement parts here and no go. So I either import it ($ + long wait time) or fix the mess.
Greg in France (03-21-2021)
Thanks, ultimately I went with a short piece of steel fuel line and a couple of compression fittings. Worked very well (so far) and looks much more respectable. I'll keep a close eye on the connections for a bit in case there's any kind of seepage but it's bone dry right now.
I'm not a fan of compression fittings, don't know why, but especially when the compression fitting is placed between two sections that can flex, IMHO, not an adequate fix. 2 separate compression fittings uh uh...
Ya gotta get the right hose/tube/line... Ya gotta.
Brother. If it was ANY other automotive liquid but gas,,, in a hot engine bay, right over an exhaust manifold, I would understand this as a temporary fix - but NOT with pressurized fuel/gas.
Doug (03-20-2021)
Nothing wrong with tee-ing into the tube (or hose) for a fuel pressure adapter. It's a useful idea, actually. It's just that it wasn't very artfully executed
Personally, FWIW, I'd have no problem with compression fittings here.
The pipe/hose assembly is #11 in this illustration:
https://parts.jaguarlandroverclassic.../brand/jaguar/
An alternative is to tee a pressure gauge adapter into the rubber section using barbed hose fittings. If for any reason you ever wanted to remove the tee it's just a matter of removing the rubber hose and replacing it with a new section. The rubber hose is not crimped/swaged onto to pipe nor the end fitting. It's all barbed-nipple assembly. Cut the hose off the barbs and press on new hose. it's just the same as replacing the injector hoses.
There is nothing worse than an engine fire and these hoses are usually the cause
I definately agree, replace the injector hoses, "they are a sacrificial part that should be replaced when doing a service (valve train clearance) as the inlet needs to be removed to do this."
Grant Francis (03-21-2021)
Thanks for the clarification; but doing the valve clearances does involve unbolting the cam sprockets/loosening the timing chain, removing the camshaft, and often having to repeat this process unless dead lucky with your measurements. On a fuel hose safety renewal, which is what is being discussed, I wrongly read it to mean that a valve clearance job is in the same sort of difficulty and complication category, which is perhaps liable to mislead the unwary. My apology for misunderstanding your point.
The 2 hoses at the rear cradle, OK, not in the engine bay, but still getting a lot of mention lately for smells and actual leaks on the dirt.
The boot hoses, waaaay outside the engine bay, but just as important, as a build up in there could go "boom" when the lid is opened and the light switch sparks, oops.
Its a scary world with pressurised fuel and hoses over 5 years old, as rule of thumb.
