Fuel line refresh
Fuel line refresh
This week I am giving some more love to the XJS by replacing thermostats and adding a fuel check valve. so I am beginning to think about next steps...
For my 92 v12 (has the 6.0 fuel delivery system) the flexible fuel lines could use some attention. The pieces that look concerning are the two crossover lines from fuel rail A to fuel rail B and also the first (last) section of hose on the fuel feed line. These three sections are of the same material and while they do not leak they appear very dry and brittle on the outside layer. Where the check valve is going on the fuel feed line, the tubing has been cut and spliced for the purpose of getting a fuel pressure reading in the past. So that is where the check valve will go. As I said, this line is brittle on the outside but holds fuel but I’m not comfortable with the outer layer. The design of the hose must rely on this layer for heat protection or abrasion protection but evidently not for sealing fluid.
I am am looking for how to have these three sections replaced, one of which I want my check valve in line.
The following 3 users liked this post by Greg in France:
Received 10,908 Likes
Carefully slice off the old hoses. Make every effort to avoid damaging the nipples. If you're really careful and patient you can probably save the existing ferrules but I just cut the old ones off and install new
Anyhow, the new hose is simply pressed onto the nipples with hand pressure.
That's it.
I use a small smear of silicone (or whatever slippery stuff is closest to hand) to ease the pressing-on
New ferrules are available from various vendors
The following 2 users liked this post by Doug:
Grant Francis (02-24-2019),
Greg in France (02-24-2019)
Greg in France (02-25-2019)
I have replaced those rail crossover hoses on a 92 XJS before and Doug and Leo are spot on with their advice. Lots of patience to cut away the old hose without damaging the barbs underneath. I was able to reuse the original ferrules. I don't know where you're located, but I have a rebuilt set of feed and return hoses for the 5.3L facelift XJS that I never used, EBC4363 and EBC4364, if you're interested. I gave up waiting on a vendor to send them back to me and they arrived a week after I had installed new hoses.
The pics and videos are of slightly different hoses. From other models, I guess. Looks simple enough. Anyone know the ID of the tubing I should use? I need to make this error free as I do rely on this car at the moment. As much as that is possible. Haha.
Also, it looks as though there’s are two styles of ferrule. Also looks to be a rather insignificant detail in the smaller ferrule type (which I have). Is this specialty tubing or will any fuel line suffice? I’m guessing it needs to be a high pressure hose???
I've used the smaller. shallower ferrules to replace the deeper ferrules many times with no problems. The shallow type is readily available but I'm sure the deeper ferrules are out there somewhere as well....with a bit of looking.
You'll want 'fuel injection' rated fuel hose. It'll usually say "For fuel injection" or similar right on the hose. Beyond that, nothing exotic is needed. Most parts stores sell gates, Goodyear, or Dayco. Any of those will be fine. Avoid the Goodyear hose with the blue inner liner....if it is still even being sold. The older v12s use 5/16th inch ID hose. I suspect your '92 does as well but I can't say for sure
Why bother with ferrules? Is there an engineering reason or something? You can get heavy-duty worm drive clamps and redo every fuel hose with that, makes for easier disassembly though not as pretty visually.
You *can* buy covers for this style of clamp but its abit much.
The idea of the ferrules is to preserve the end of the hose. If left unprotected the layers of the hoses might....probably would, eventually....deteriorate and the integrity of the connection would be lost.
I know some have not used ferrules and reported no problems, at least in the short term.
IMO, they might not be 100% essential....but I can see no compelling reason to avoid using them.
Constraining the end of the hose is what the ferrules are supposed to do. They compress the end only, preventing the hose from moving up the barbs without pressing the hose into the barbs. Just try removing a hose from an injector with the ferrule in place, then again without the ferrule. You’ll see their function.
Today I replaced the splice with a check valve and have three for three quick starts without having to “prime” my fuel system. I am super pleased so far with the check valve solution.
However, I found the seal going from the feed line into the fuel rail has totally failed. I replaced with an o ring but this is not an acceptable solution. I have heard these seals are difficult to find for the 92-96 fuel rail system.
Anyone know now where I can find this seal? It looks like it was a custom shaped seal for this fuel line.
Greg in France (02-28-2019)
S
Thank you Greg. Unfortunately what I have found is this particular seal has been discontinued. Several calls to Jaguar specialist suppliers yielded the same answer.
So, for those of us with the late model (92-96) fuel injector rail we have no supply of the original seal.
Has as anyone solves this another way? I had a standard o-ring on hand and it has held for one day but it is now my biggest concern, more than the hoses which we all agree need to be replaced.
Please help if you have the exact solution!!
Try Mr Injector. https://mrinjectoruk.co.uk/
Did you try https://www.jaguarfuelinjectorservice.com
and what is the part # your looking for?
Edit:
Is it the oring listed here for less then a dollar?
Edit:
