fuel pressure regulator leaking
The fuel pressure regulator on the left side is leaking fuel out the vacuum port. I'm going to assume that this is just a bad regulator...but is there anything else that might be going on to cause this?
Secondly, in looking for a replacement, I see that some parts dealer specify "inlet" side and "return" side, while other don't mention any difference in the regulators at all. Since I have to drain fuel to replace one, I might as well replace both, but I'm seeking clarity of if there is a difference between the two..especially since I can't seem to find a "return" regulator at all, but there are plenty of "inlet" regulators at decent prices.
Thanks,
John
1987 XJ-S V12, 62,000 miles
Thanks,
John
Nope. It's toast :-)
RH regulator = inlet regulator
No absolute need to replace or even keep the inlet regulator. The engine will run perfectly well without it. Many guys ditch 'em
