fuel pressure regulators
Received 10,880 Likes
Hi Brad
Did you eliminate the FPR on 'A' Bank as Greg and Grant advised rather than replacing it with another one
If so try that first to see if she runs ok
Though in the event that you wanted to replace the FPR on 'B' Bank anyway, then as 'Doug' said that is a different Part Number and a totally different fitting with different Connections to the one on 'A' Bank
Greg in France (04-14-2021)
Hi Brad
Here are the two FPR valves in my 1983 XJS. One is 234 the other is 229, are they the correct ones fitted?
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20210419_150623_7e66bb975ab9606511e3d6552762e2f9e36e6fbe.jpg)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20210419_150630_54e4b869a6c6d909c889b5d76d1e5bf34fc14224.jpg)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20210419_150646_ff83d41b49f7eaff4860437393b6d151446e4559.jpg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20210419_150654_36db997966cbf7e13ccabd8c15e41ccd4e75b750.jpg)
After much deliberation, with myself, I have decided to replace both of them rather than by pass one of them..
Are the codes for new replacement FPR's these ones?
Lucas 73232A 4RV I would hazard a guess at Bank A
and
Lucas 73239B 4RV another guess at bank B
Thank you.
Graeme.
look up the correct part numbers on this website:
https://parts.jaguarlandroverclassic.../brand/jaguar/
This is the actual page:
Then order those parts from Manners or any other specialist supplier. Aftermarket non-Jaguar packaged ones are fine, as long as supplied by a specialist.
The following 2 users liked this post by Greg in France:
Grant Francis (04-20-2021),
orangeblossom (04-21-2021)
Graeme
The following 2 users liked this post by Geewhite:
Greg in France (04-19-2021),
I order tow new FPRs as well rather than try to later the original set-up which seems to work just fine. This will be my Saturday AM project.
As the FPRs look identical you have to rely on the part numbers to know which side get the higher pressure rated one.
Fingers crossed it works and from there it is onto sorting out some electrical issues with the lights.
The following 2 users liked this post by Doug:
orangeblossom (04-21-2021),
ronbros (04-21-2021)
It took me 80mins to change both of them, 19mm spanner, 14 mm spanner, 13 mm socket, flat head for prising, long nose pliers, T40 torque. A small plastic cup( Pakora sauce size) for catching fuel, I put it back into the tank
Undo the bracket that they are attached to, much easier to get from underneath when they are off.
Hope this helps.
Gee.
True, they are different sizes slightly, but they only fit onto the one they are meant to fit onto, which helps.
Hope this helps.
Gee.
Hope this helps.
Gee.
I contacted McMillan Jaguar in Motherwell, not far from me, he mentioned that I should check the hose to the ECU, it may be blocked he said.
There should be a vacuum, I checked it, there "Is not a vacuum". It's split by a T-Piece as well, pic below below.
I blew down it, no back pressure, air is getting out somewhere, either by the t-piece or ?
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20210422_095502_e0e5077aa0705194b2f48a8d50e6eb0e72e54523.jpg)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/20210422_095509_242c23b816c2b8c38076948409e049fee4034d8c.jpg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20210422_112350_7947a9de8c86e7217f0e76bd908c1241f66af865.jpg)
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/20210422_172509_e10d82109d3204616f3b0353ac0654f789bf50bf.jpg)
Geewhite (04-23-2021)
The T piece sends vac to the Rochester valve, which is a small black round flatish thing hidden up the side of the tank. This valve vents the tank to atmosphere, but needs a slight vacuum to open it. The idea being that when the car is stationary the tank cannot vent, but when it is running it can. Your Rochester valve may have failed; but as long as it fails open, it does not matter! On UK models, like mine, with no vapour cannister recovery system, this valve was fitted roughly where part number 28 is arrowed in this diagram in the link:
In USA cars, the Rochester valve was fitted in th engine bay as part of the vapour recovery pipework, but it has the same function; to seal the tank when the engine is not running, number 8 in this diagram in this link:
Block off the T arm that does NOT go to the ECU, and then test for vacuum as below.
The vac source comes from the balance bar across the back of the engine that links the two manifolds. Sucking on the ECU end will show some resistance, but you will be sucking some air through the butterflies, remember. If there is a bit of vacuum doing this, then the vac line is probably OK. If not, then this has to be investigated further, so post again.
The following 3 users liked this post by Greg in France:
Just one point, this is a vacuum pipe, should I not blow down it?
Cheers,
Graeme.
