fuel rails, for new bosche injectors
XJS (edit because of stupid tablet) runs very low rail pressure I think it is around 20psi.
I have kind of made the assumption if the injectors - say L67 which is the GM 3800 supercharged V6 - can make 400hp from 6 cylinders on stock injectors the V12 could make 800hp with them.
There are other considerations - like the impedance this is the dynamic resistance (AC resistance) as the impedance changes say drops the injectors will cause a back EMF (voltage) to the ECU this could cause the ECU issues if it too large. As the injectors are switched This is an AC current they will act like an ignition coil causing a spike in voltage hence the need for ballast resistors.
So here is the email reply I got. Sounds like he's done his homework!
View full HTML message
Hi Jamey
With my car I have a Wolf computer and many other modifications to the
engine to produce 450HP.
You can change your injection system to aluminium fuel rails and modern
injectors, still driven by the normal computer.
The rails you can buy from Ed Ward edmund.ward@cummins.com
The injectors you can use are Jaguar ones from an XJ40 available from
http://www.ebay.co.uk/itm/JAGUAR-XJS...ET-OF-6-EBC443
0-/200790889046?pt=UK_CarsParts_Vehicles_CarParts_SM
<http://www.ebay.co.uk/itm/JAGUAR-XJS...SET-OF-6-EBC44
30-/200790889046?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item2ec011d256>
&hash=item2ec011d256
Buy two sets to get 12 injectors. They will fit into the existing manifolds
and into the aluminium fuel rails.
The existing injector wiring as is can be used, I'd just recommend changing
the plugs to the later model Bosch
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem
<http://cgi.ebay.com.au/ws/eBayISAPI....m=190667144318
&item=190667144318
With the fuel rails, you can get rid of the two pressure regulators, and
install an adjustable one
http://www.ebay.com.au/itm/NEW-RISIN...ATOR-KIT-ADJUS
TABLE-/180523452601?pt=AU_Car_Parts_Accessories
<http://www.ebay.com.au/itm/NEW-RISIN...LATOR-KIT-ADJU
STABLE-/180523452601?pt=AU_Car_Parts_Accessories&hash=item 2a080948b9>
&hash=item2a080948b9
When doing so, run the fuel supply to the rear of the engine and connect to
the fuel rail, and on the rear outlet side mount the pressure regulator then
to the return line.
While you have everything out, I'd suggest you also change the heater tap
from the metal one that rusts and clogs, to one of these plastic ones
http://www.ebay.com.au/itm/Heater-Va...6-2004-/300544
258534?pt=AU_Car_Parts_Accessories
<http://www.ebay.com.au/itm/Heater-Va...V6-2004-/30054
4258534?pt=AU_Car_Parts_Accessories&hash=item45f9d 571e6>
&hash=item45f9d571e6
I am in the Newcastle area if that's handy for you to have a look - but then
again you could be in Perth!
Any other questions, just ask,
Ian
Hi Jamey
&item=190667144318
to the return line.
Ian
Received 1,236 Likes
thats the arraingnment i did in my XJS pre, back in 1995, i used honda injectors(cant rmember what #), custom rails , and XS FPR at the end, all easily available parts, at a fair price.
only thing i do remember is they flowed 21lbs at 43psi, low impedence. there was not much available back then, if i were to do over id use the new small style injector(Bosch).
course you could drill into the head and install DIRECT injection , and run 2200psi fuel pressure, that would probably ATOMIZE quite well. hehe
ron
ron
A couple of thoughts here.
First I think the quad throttle body idea I would give a miss. It has one major flaw in that it will align the throttle bodies with inlet runner 2 and 5 - not an ideal situation, this goes against all of the principles of not aligning inlet and outlet ports in a manifold plenum. The front throttle idea I like if it were me this is the way I would go. It has the advantage that you can increase the length of the runners for better torque. Although a custom manifold would need to be fabricated.
The V12 as best as I can determine uses 24lb injectors but the fuel system only operates at 30psi meaning the stock injectors will support 400hp at 43.5psi and 450hp at 50psi with an 80% duty cycle. So if they are ok why replace them unless they are working above their duty cycle.
I am also not convinced the XJS needs bigger TB's they are 63mm each giving a total area of 623cm2 which is equivalent to almost 90mm throttle on an LS1. The inlet profile on the TB's is appalling and would definitely benefit from an add on bell mouth. I would not machine a radius on the throttle housing as this will impeach on one of the mounting screw holes creating turbulence. I would find a bolt on bell mouth that fits or is close and modify it.
FS[SouthEast]: X300 XJR engine & misc parts
knightofgold
02-11-2016 06:03 PM
