fuel smell in oil
thanks for reply,ok so its basically running past the piston rings due to not being detonated by spark.the car has also set for a few years.is there a way to pump oil through the eng after oil change Ofcourse.? can the distributor be removed and turn the oil pump with a long flat bit and a drill.?so eng doesnt start dry?
