Fuel sump tank
Whats the matter? You'all don't want a free trip to Mexico??? I've tapped several off rings off all kinds of Gas tanks with punches, screwdrivers. I guess it would be possible to go Boom. But I don't ever remember seeing any sparks, ever??? I have a sneaking feeling, they made the ring, and the other pieces around it of a metal that won't spark, when struck with another piece of metal, Correct me if I'm wrong but I think it would be a ferrous metal? Maybe we've got an engineer on here that can set me straight?
Jack
Jack
While I don't have the confidence in automotive engineers that Jacobra does... If you're using enough force on a screwdriver or punch, to create sparks on your gas tank... You're probably doing something wrong. Apply common sense, be careful, and use the best tool that you have on-hand to get the job done.
Right... IMHO,,, best tool,,, ALL things considered - would be wood... Kinda gives a little and grabs nicely, too. Jus say'n. Sparks can be and often are micro. Then, factor in that you are working in the light and not looking for it - many sparks are missed. Static electricity can even cause problems with fuel. Safety first.
