Fuel Tank Padding?
I'm in the process of swapping out the gas tank in my '89 coupe.
I bought a new tank and installation kit from SNG Barratt.
The installation kit, among other things contained black foam, about 1/2 thick, which I assume is replacement foam for what was used on the original. No instructions though.
Problem is, it looks like the tank has been out before, has thinner white foam padding, so its not clear to me how the foam padding is supposed to install, be it on the top or bottom of the tank.
There are the triangular pieces that go on the sides like on the old tank, but there are also several other pieces, one the width of the tank, and several other narrow pieces. Do these pieces 'stack' on the top of the tank?
Any help would be appreciated!
The foam goes under and behind the tank. There are also foam pieces under the straps that hold the tank in.
While you have the tank out there is a pop rivet on the right side put in from under the car. This rubs on the bottom of the tank, if it has not already been fixed remove the rivet and install a new one from the top, ie from under the tank.
The following 2 users liked this post by warrjon:
Greencar89 (04-18-2016),
orangeblossom (04-16-2016)
here is a link to my fuel tank replacement project
there are some pics of the new and old tank
https://www.jaguarforums.com/forum/x...cement-142961/
it may help
BB
it may help
BB
it may help
BB
it may help
BB
Excellent write up and great pictures! Very helpful!
