fuel tank vent routing
An easy trick for working on fuel tanks and determining which line does what is to blow into the fittings. Vent fitting will allow air straight in and fuel return will bubble if there is any significant amount of fuel in the tank. The pressure line is obvious as it's the one that has fuel pressurised in it and is usually the largest.
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
