Gareth’s XJ-S Resurrection Thread
I’ve just bought a 1987 British Racing Green V12 Coupe. Exactly the XJ-S I’ve been looking for. It’s rust free and has been sitting garaged for 5 years, mostly untouched. The seller is moving and needed it to go away, so $100 it’s mine. It would have been $2000 if the economy hadn’t suddenly collapsed.
So here’s what I know of the car’s recent history. It was bought in 2014, and ran well without any problems until it was put away for the winter. In the spring it ran roughly, fresh gas and injector cleaner made better but didn’t totally solve the problem. I know it broke down and got towed once in the spring of 2015. The seller, now previous owner, did some work, but he’s quite tall and retired and found working on such a low car uncomfortable. So it sat. Now I’m trying to get it going and back on the road. So far it has a fresh battery and fresh oil and it cranks over but doesn’t fire. I have no idea of there is any gas, the gauge says no, but I don’t trust it. I’ll work through the very helpful no-start HE sticky, but before that I’m hoping you can all help me identify a few disconnected wires. They may or may not be crucial to starting, but I’m sure they’re there for a reason...
First up is this little green guy on the A bank, looks to be two spades in one socket.
Next! We have these two. They could plug into each other, but they’re coming from the same place and I’m not sure that makes sense. Also on the A bank.
Overlooking the acorns, that connector goes to the cruise control right? The cruise control itself is in a box in the trunk. There’s quite a bit of red sealant on the bellows, and a new in bag bellows right next to it.
There is this fuel line with a filter no connected to anything. On the B bank side of the car, comes in near the brake cylinders, is this the fuel return?
Vacuum line? Or maybe really big vacuum leak? A bank
And finally, this doesn’t look original somehow. Not sure if it’s hooked up to something or not.
Someone cut off the intake trumpets, I always thought they looked really cool. I’ll have to get a set once it’s running.
The following 3 users liked this post by garethashenden:
Welcome to the Forum. A few answers, but not all by any means.
The Vac tube off the front of A bank is I think part of a complicated advance/retard system or the cruise control safety system. I am pretty sur it goes on that little plastic spigot beolw your little finger, level with the line in your palm, just above the aircon hose silver ferrule in the photo.
The Intake trumpets have gone because the previous owner has installed a cold air intake mod. This is a good idea for power and efficency at high revs, but keeping or not is up to you, obviously.
The little fuel filter thing is to filter the air that is sucked through the dizzy cap as par of its design to keep it fume free. If you follow the line it goes to the dizzy, and one exits the dizzy to the b bank intake - hard to see it bit it does.
Fuel: I would look in the boot (trunk), under the battery is a small petrol tank which is fed by the main tank and w#from which fuel goes to the pump and to the engine via a filter behind the spare wheel. Under the small tank is a hole in the boot floor, if you look under the car you will find a rubber grommet in the hole. Remove the grommet and undo the bolt which is a drain plug for the small tank. Drain all the old fuel, replace the plug. Then undo the locking ring on the tank and look inside, you will find a filter over the exit pipe, change it and clean out the tank. Also change the fuel filter being careful to note the direction of flow. Then before fitting the new filter, undo the pipe leading into the A bank FPR in the engine bay and blow out the fuel line. Then new fuel.
If you get stuck in and enjoy fixing cars you will end up with a great GT car, but be prepared to have to renew all wearable parts such as suspension rubber, ball joints, coolant hoses (all 14!), spark plugs, HT leads, distributor cap and rotor, shockers, etc. Work methodically and all will be well. And everyone on here will do their best to help, that is for sure.
Greg in France (04-01-2020)
Welcome ... if your not already gray and thinning you will be soon!. But seriously what an excellent buy.
With a bit of luck there will not be to much wrong with the car and you will have some fun fixing it up.
Some seriously good help available on this site... also look for "The Book" "Experience in a Book" by Kirby Palm, it is a bit of light reading on the XJS and available free on the net.
PDF - 722 pages LOL
Keep posting pictures as we all like to see people age before us...LOL
PDF - 722 pages LOL
Wow what find, and what a buy! Follow the so you got a V12 that won't start sticky to the letter, and in a few hours she'll be purring like the kitten she is. Greg's advice on the fuel system is spot on, and equally necessary. Good Luck, and I think we're all a little jealous. Wow! I can only wish mine looked that good. Congrats!
Jack
Jack
The following 2 users liked this post by 89 Jacobra:
Doug (04-01-2020),
We’re practically neighbours! I’m in Fitzwilliam (for the sake of the rest of the forum, it’s the next town over). I’m pretty sure I know where you live, if you’ve got a large barn and a Mark X/420G out back.
I’m having trouble getting the drain plug out. It’s not centred on the drain hole enough to get a socket on it, and I must be using the wrong size wrench, because it either won’t fit or won’t grip. I’ll get an 11/16th and see if that’s the right size, it’s in between the two I’m using. Most of my tools are metric since that’s what all my other cars have been, 2 BMWs and an X350. More tools is always the answer right?
Moral of the story; find someone who is selling the car you want because they are moving.
I actually had the sump tank removed from the car at one point & I didn't dare put any more force on that bolt when trying to undo as I thought it might actually tear/distort the sheet metal of the tank, so ended up leaving it in place.
I found an easier way to drain the fuel is to take the hose off the fuel filter, stick it in a container, & bridge the fuel pump relay so it empties the tank.
As greg said shove the vac pipe onto the end of the blue solenoid valve. Connect the black and yellow wires back together. They are part of the cruise and wont stop it starting. I'd trace all the after market wiring. Looks like theres plenty of earths on it and a relay built in but electrics aren't my forte. Good luck with the car it looks nice. Add a nought to your budget to start with. Ask me how I know. Lol
Greg in France (04-02-2020)
So, it turns out that when you’re trying to undo a bolt it matters which direction you turn it. Who knew?
Anyway, I was able to loosen the drain plug and some gas dribbled out. Then I realised I didn’t have enough time to finish the job before I head to work, so it’s sealed up again should rain all day tomorrow, so Saturday the plan will be to fully drain the tank and change the filters.
Hello and Welcome.
On top of the already important list, that yellow plastic fan needs to go ASAP.
They are renound for exploding and i think i know why, they get old and brittle...............................as do engine mounts, When engine mounts have failed and you give it some welly the fan will touch the shroud, you can hear this with the metal fan, im guessing with the brittle plastic when this happens it just explodes.
lts a long list, but if you like a challenge and have a curious mind you will have fun and a great deal of satisfaction.
When draining the fuel out of the surge tank, how much will be left in the main tank? It’s currently dribbling out, but there’s still a bit in the main tank, maybe a gallon. Is this normal? I want to open up the surge tank to change its filter, but not until it’s empty. The flow has defiantly slowed down. Here’s the view inside the main tank at the moment.
