I am slowly piecing my 94 XJS back together after a 5 year long painting project. I vaguely recall tossing the torn apart outer door handle gasket, and it must be true because I cannot find it. I refuse to pay $40 for rubber or foam gaskets, which brings me to my question.
Are these simple gaskets? Are they made out of rubber or foam? Has anyone made their own gaskets for any car and where can you get the material. 5mm thick rubber should do it?
A while back I bought two new door gaskets for my '95. They are molded rubber. At the time I bought mine they were NLA; however, I was able to get one from a supplier and the opposite side off ebay.
the ones in the link are not what I was expecting, or what was in there before. before it was just a rubber gasket without the extruding parts.
I discovered I could cut some of the foam off the door pads under the door panels. It is a perfect height and like what was in there. There is a bevel, so I just cut pieces to fit in the bevel with a little gorilla glue and it works. Ill be installing tomorrow.
well done. the pic is probably generic it would have been the BEC8979 probably I think the dearer one is the illustrated one,
but you have done a good job on that.
It says the part was superceded by this part number. Yet this part number is said not to fit? ? My confusion on all this made me make my own. Yet the correct one would be much better. Mine will probably cause issues in the long term...
