gasoline in oil???
Good point that oil in 1987 isn't as oil is today. I went with 0W because I think it's important to get oil everywhere ASAP. Our weather will usually break in early-mid March, and then I'll change it again. It won't need it in terms of mileage, but as Grant said, oil is cheap. I'll likely never be able to afford another engine, so taking care of this one is mission #1.
Jagboi asked how far I drive it. Not very (I'm retired), but I do find myself taking longer paths to my destinations just to get the engine up to temperature, which is as good as an excuse as any to drive it and drive it and drive it
Thanks,
John
Thanks,
John
The following 2 users liked this post by J_C_R:
Grant Francis (01-25-2019),
Greg in France (01-26-2019)
It’s not the 0w number that concerns me here....but the 20 that comes AFTER the w.
w20 seems to be a Jaguar accepted weight for the hotter temps, not the colder temps. Personally, I believe 0w40 is the right oil for both the I6 and the v12 engines. It’s got the low cold start weight number that’s useful under any climate, and then turns into a jack-of-all-trades 40 weight when engine is hot.
I wouldn’t run w20 in theI6 or v12 regularly.
Thanks for that Vee. The problem I have here is that it's very difficult to get it up to temperature (180 F or so) when it's cold, and that's with 95% of the radiator blocked. I've decided to prevent overheating in the summer...this done by ditching the engine driven water pump and fan, and installing an electric water pump and dual electric fans...and accept that winters are going to present a challenge. Normally it's in a heated garage in the winter, but circumstance dictate that it sit outside this winter. I don't mind the chilly drive, I just want to save the engine. So I now have an oil pan heater in place which should help.
I will add that while it's surprising to see an XJ-S on the road any time of year, I do get double-takes due to driving it when it's -5 or so out...the fun never ends
Thanks,
John
Thanks,
John
It remains a fact that, at 80 degrees C or above, there is no virtually viscosity difference between 0W - 20, 30 or 40 weight oils. Take a look at this and fill in your desired weights, you have to get to 15W - 40s before any significant high-temp viscosity differences appear. Always assuming the link provides accurate results, of course.
https://www.widman.biz/English/Calculators/Graph.html
The following 2 users liked this post by Greg in France:
Grant Francis (01-28-2019),
J_C_R (01-27-2019)
greenarcher83
07-05-2009 06:32 AM
