Getting at the rear end
I'm planning on tearing into my rear end this year, and I've done a bit of research on the site as to the best way to do it. It seems that the common thought is to jack the back of the car waaaay up, then drop the diff down and wheel it out. I kind of don't have the equipment for that (or the cojones).
Basically I was wondering if it's feasible to just dissasemble the rear end piece by piece; drop the bottom plate, drop the diff, pull the axles out, etc etc? That way you wouldn't have to have the car up very far, just high enough to give you working room. Would there be a hiccup with reassembly maybe?
Received 10,871 Likes
Your plan could work if you don't need to remove the actual differential itself...because it's bolted to the "cage" at the top. To unbolt it you'd have to drop the cage to access the bolts.
That said, the car doesn't have to be lifted all that high to remove the whole assembly....maybe 20" or so.
As Doug says, you have to take the whole shebang out to do a full job.
Actually, it is fairly easy to remove the back subframe complete, but you can sometimes have difficulty with the exhaust system if it wont come apart due to rust. You support the car in front of the radius arm body mounts here using substantial wood blocks or axle stands, leaving the suspension up in the air. Make sure car is secure and steady before going underneath, this is of paramount importance.
Disconnect everything, (brake lines, propshaft. radius arms), then, using a heavy duty jack with a good height lift capability, jack up to support the subframe underneath the diff. You can then undo the bodymount bolts, remove them, and then gently, using the jack, lower the subframe to the ground.
Depending on the height involved, use one or both tires as a backup to the jackstands by sliding them under the car on their sidewalls.
It has enough height that if the car comes down, it has to come down past the tires to crush you.
Even when not getting under the car it can be useful. For example, working on a brake at a corner, you still don't want the car coming down while your arm is between the hub and the fenderwell. Well, with the car jacked up, just take the tire and slip it under the rocker panel.
Disclaimer: Anyone using the methods outlined above does so at their own risk and must consider their own circumstances carefully.
Great point! The same thing happened to me the first time I dropped the cage. It sounds so simply and silly but it really did have me stumped.
Take pictures of everything before you remove it, not just the exhaust. I just removed and rebuilt my inboard brakes, shocks, etc. This was the first time I ever owned or worked on a Jaguar, so I understand your concerns, but once you get going on it, it wasn't as difficult as I thought it was going to be. Just a couple of suggestions, presoak all the nuts and bolts for several days before you start the removal with some kind of penetrating oil, I actually used Marvel mystery oil and not one nut or bolt was locked on. Also I had to cut my exhaust pipe just beyond the cage as well as remove it from the mufflers, I was able to get the clamps off, but the 2 pipes would not come apart. I also used a digital camera and took many pictures from all different angles, they came in very helpful when putting it back together. Good luck
Thang Nguyen
10-12-2015 01:25 AM
