giving up on the 700R4
Old 10-11-2014, 11:18 AM
Received 2,192 Likes on 1,358 Posts
HMMM Ive had a 700R4 in my suburban(5500#s) for years behind a 400hp 383 with a 300hp NOS fogger in the intake w?3.90limited slip. After I started building them myself they started living. Funny I never could get a pro built trans to live past a yr. The only thing I have ever had a issue with was the 3/4 clutch pack. I upgraded that with a commercial unit with 9 clutches instead of 6. and it is right in front. pull the pump and slide a new one in.
Built it with red line clutches, kollen steels, 10 vane pump and corvette servos/accumulators. B&M valve body kit. More weight and I pounded on that thing and raced it. But I would agree if youre having issues go to a 4L80E. you can do alot with that trans but not cheap.
ronbros (10-12-2014)
  #42
Old 10-11-2014, 11:42 AM
M90power's Avatar
That would be the way to do it. I built mine with sonnax springs, and green clutches. I didn't want to sink a bunch of money into an automatic when I really wanted a 5 speed. Good call on my part because the MTV up shift valve seized up in the VB after a couple of miles and annihilated my friction unit.
I just put in the order for my wildwood floor mount pedal and master cylinder, and my 6 puck ceramic clutch and pressure plate.
  #43
Old 10-13-2014, 12:12 PM
Originally Posted by m90power
that would be the way to do it. I built mine with sonnax springs, and green clutches. I didn't want to sink a bunch of money into an automatic when i really wanted a 5 speed. Good call on my part because the mtv up shift valve seized up in the vb after a couple of miles and annihilated my friction unit.
yep incorrect tv adjustment is a big killer of the trans. Too low pressure and its slips he clutches and burns em up fast. Another reason i like a 4l80. Car adjjust everything from line pressure, to shifts, lockup etc.. And its basically a t400 with overdrive and electronics. Or.... Could always stick o gear venders overdrive unit on
ronbros (10-14-2014)
  #44
Old 10-14-2014, 06:25 PM
M90power's Avatar
those gear vendors are more than i paid for my engine, trans, and supercharger setup/mods combined.
the TV cable was adjusted perfectly. the problem was the MTV upshift valve which is entirely different.
  #45
Old 10-14-2014, 06:33 PM
Bc xj's Avatar
I looked into Gear Vendors for an underdrive unit, it was over $2500. Would be great to have 3:91 or 4:11's at the flick of a switch. But to rich for my blood.
Having said that it is on the list. Not much more than changing tranny and gear set. Both fun and economical settings.
  #46
Old 10-14-2014, 11:31 PM
calvindoesntknow's Avatar
So did we grab the t5 yet? I wanna see this beast with a manual, which is what I advised you to do several years ago if you remember
tomkilner
10-09-2015 07:10 AM
brgjag
10-06-2015 09:27 PM
Spazzzzzzzzzy
XJ40 ( XJ81 )
10-05-2015 04:05 PM
Glenn Barickman
10-01-2015 04:09 PM
Fraser Mitchell
10-01-2015 07:20 AM
Quick Reply: giving up on the 700R4
