GM V12 aluminum LS series.
Received 1,236 Likes
i was just looking at some pix of an experimental GM LS engine ,
V12 8.5L, interesting if nothing else, this i not new ,back around 2006 a PRI show in Orlando FL, at the GM pavilion they had an LS straight six head ,when i asked about it,guy said for a V12 LS.
that would make a cool engine ,LS are proven performers, and lots of info since they came out.
time will tell!
time will tell!
A V12 LSx would be pretty amazing to see, though I'm not sure what they would use it for. High end Cadillac? Big truck? It would be too long to fit a Corvette. An LSx based V4 or V6 would be interesting as well.
The neatest thing about the LS is not only how much power they make, but the packaging. The pushrod 2-valve design makes it one of the most compact engines made. A 7 liter LSx is tiny compared to most other engines of similar displacement and every aspect of the engine is designed to be efficient and durable.
Jaguar and many other manufacturers have successfully made V12's, why couldn't GM? I doubt they'd go through all the trouble of designing a modern LS V12 without taking into consideration all the variables.
jameys correct just think about it, at this point GM wouldnt R&D it if it wasnt going to make some hi end cars to put it in! and for your interest GM actually made a V16 Cadillac LS engine, back around 2003, supposidly made 900hp N/A, i got pix of the whole car, very big and long limo type monster, never made production tho.
and that old GM thunder junk is just that, how do i know experiance(61yrs of engine work), yeah i'm an old guy,lot older than 61) i have rebuilt some of them, never designed for any hi-performance use, and super heavy, all cast iron, low rpm, max 3800-4000.
and if of interest they were called TORO FLOW because of the port design lot of swirl, guess where GM got the engineereing for the famous Vortec ports,DUH.
and they were made in V6-V8-V12.
Hey typhoon what about the Buick GN with 90* V6 turbo engines, i wouldnt say they were all that bad, i have seen some make 600hp, they were the fastest full body cars made in 1987!
I wonder if the is the same one, just showed up on Motor Trend today GM LS-based V-12 Under Construction, Bound for 280 Z - WOT on Motor Trend
They made a V12 and V4 from two V8s. Being a pushrod V12 I bet it sounds very nice and farty.
FS[Western US]: XJS V12 Convertible
marklcap
09-29-2015 12:41 PM
