governed at 4000 rpm???
Received 10,938 Likes
If yours is an earlier '89 with Lucas ignition you most likely have a failure of the secondary ignition coil....the one mounted in front of the radiator. Replace it, or replace both original coils with a single DAC6093 coil.
If yours is a later '89 with Marelli igntion....well...I'll have to mull it over a bit.
In either case a fuel delivery problem could be at play.....but let's clarify which ignition you have first.
lubalb (02-19-2012)
Mine is an earlier with a Lucas ignition. Went down to look for the garage to look at the ignition coil in front of the radiator and there isn’t one im guessing it was attached to the to white wires hanging there and the other coil is not a single dac6093 so im guessing that’s my problem. Thanks for the help Doug where’s a good place to get the replacement coil.
Jaguar Forums Editor
Jaguar Press release
09-28-2015 05:18 PM
