Grease Fittings for 96 XJS
First off, I would like to thank all the members who responded to a couple of Threads I posted earlier. This Forum is great.
So, another question: Going in for a routine oil and filter change soon. Is there any grease fittings that should be inspected and fresh grease added if needed ? Or are all the fittings considered sealed ? Thanks for any assistance.
Rick
Rick
Rear axle:
Under the diff, accessible through the holes in the bottom tie plate: 4
One on each UJ on the driveshafts: 4 in total
On the pre-facelifts there is one on the bottom of the hub carrier casting, I am not sure about the facelist cars.
There may be a nipple on the front hub, the front wheels have to be removed to find it.
A couple of pumps on each nipple will do it.
