grinding noise
Old 04-05-2015, 11:18 AM
yabaman's Avatar
Smile grinding noise
Hi guys
I am getting a kind of a grinding noise in the rear of my 1990 3.6 XJS.
It gets noisier as I increase speed. Makes the same sound either when I steer left or right. Is this a bearing problem or anything to do with the brakes?
Any help appreciated
Old 04-05-2015, 12:27 PM
superchargedtr6's Avatar
My experience tells me that if you get grinding from the differential, you need to be ready for complete failure. Ring and pinion gears don't do well out of alignment. I would bet it is one of your hub bearings, and maybe even the carrier bearings in the differential.
yabaman (04-06-2015)
Old 04-05-2015, 07:46 PM
sidescrollin's Avatar
bearing probably. Jack up the rear end and go to each side and spin the wheels some while listening for noise and feeling how smooth they turn. Get under it with a stethoscope, tube, or even long screwdriver and listen to the diff and hubs while you spin.
Old 04-06-2015, 05:08 AM
yabaman's Avatar
Wow i really hope its just a bearing situation and not a diff problem.
Thank you guys, much appreciated
Old 04-06-2015, 01:32 PM
Could also be a bearing in the diff. Don't forget the u-joints! There is like 5 of them in the back end! Grab the half shafts and see if you can wiggle them around and check there for noise as well.
yabaman (04-07-2015)
JimC64
31
05-30-2016 03:04 PM
inactualis
10-02-2015 11:13 AM
baskervillema
10-01-2015 06:43 PM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
ChrisJay
09-27-2015 09:08 AM
Quick Reply: grinding noise
