Haha stop leaks not going to help that! Fml with a side of holy backfiring crap!
Steering rack has to be replaced now...
Fountains of fluid
Could this just be bad timing?
Exhaust bambams
Fountains of fluid
Exhaust bambams
Hello 944
For your fountain of fluid. When you paced that new seal in, was it tight in both the housing and the shaft, ie - did you slide it down the shaft to check, before you installed it in the housing? I know you installed a new nylon washer to act like a thrust washer and it is close to the exhaust, as another member mentioned - but it should have been right
Did you, have you played with those power steering lines that connect to the box. I had to play with mine recently - one of those jobs where I should have stood back and had a bit of a think before I attacked.
Anyway - I buggered up one of the fittings, and I could not get it to seal - resulted in a leak like that. (least I predicted it would have been if I started her - it was dripping just under gravity).
Regarding your exhaust bambams - did you ever check the fuel pressure. I think you posted recently where you cleaned the fuel filter out again, which was not pretty.
Hang in there - looked a real nice racing green paint job
Steve
Steve
944xjs (02-16-2020)
Received 10,872 Likes
Yes, do check the fittings (and hoses) before condemning the rack.
As for the bambams, I don't think it's a timing issue....although some other ignition fault is possible, as is a fueling issue. My gut tells me it's a secondary ignition issue- plugs, plug wires, something like that. But you'll just have to start checks, inspections, and tests and eliminate possibilities from the list
944xjs (02-16-2020)
Hello 944
Steve
Steve
I haven’t had an opportunity to check fuel pressure yet.
I usually use 93 octane. It has 87 in it at the moment. Octane doesn’t change the backfiring. O2 sensors are original, cleaned them before I put the downpipes back in. TPS was checked out like a year or so ago... was working good.
Im not even going to try again. I’m going to get a refurbished rack and not worry. I can’t even believe I’m going to do this again.... in a couple weeks or more. By then the pain will be forgotten.
