hard shifting transmission
Just wondering if any have experienced this situation and what is the cure?
Occasionally my 94, 4 litre decides it dosen't want to shift up through the gears smoothly. The transmission light will come on and shifts are very fierce. If I pull over stop the car and turn it off / start it again, all is OK until the next time. This may be a day or two down the road, or almost as soon as I start driving again.
I don't worry about driving the car, there is no transmission slippage or hesitation. trip from Toronto to Cape Cod last year turned out well though we did have to stop a few times due to the condition mentioned above.
I replaced the transmission computer located in the trunk but this made no change to what I have described.
Looking forward to your input.
Bob
Bob
to Sidescrollin and Moff1959: I'll definitely have the mounts checked, but I expect the hard shifting would be consistent and not occasional if they were to be faulty and causing the problem. I'm hoping a read of error codes will be my best bet.
Oh, by the way, just found the thank you button, so belated thanks to all.
aholbro1
08-05-2021 05:02 AM
