Harisson A6 Compressor check
Old 01-31-2017, 10:41 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Well, as the engine bay looks like below, new hoses and rings are no worries
Old 01-31-2017, 02:28 PM
warrjon's Avatar
Received 2,577 Likes on 1,712 Posts
Originally Posted by Jagboi64
Sounds like you need to go over the system and replace all the O rings. What I do is I have and industrial hydrocarbon detector good for 5 ppm. I give the system about 30 psi of BBQ propane and then go over every joint with the gas detector. I can usually find any leaks quite quickly.
You will need to replace the O rings and hoses to run R134a, I did this mod 6 years ago and re-gased with R134a and my AC is still cold.
Old 01-31-2017, 03:04 PM
Jagboi64's Avatar
Received 3,222 Likes on 2,118 Posts
With the engine out is a good time to change the O rings on your expansion valve. Be very careful and gentle removing the nut, make sure to use a backup wrench on the valve so the evaporator is undisturbed. It's easy to break off the fitting, and then you are stripping out the dash to fit a new evaporator.
O rings are a standard size in most cases, usually #6,8 or 10. You can get kits that have a number of these. The O rings on the back of the compressor are different.
Greg in France (02-01-2017)
Old 01-31-2017, 03:05 PM
Jagboi64's Avatar
Usually different oil too. With everything as far apart as Daim has things, it's a good time to flush the evaporator.
Old 02-01-2017, 02:09 AM
Greg in France's Avatar
Received 9,447 Likes on 5,529 Posts
Daim
A great idea to change the actual valve too, as well as the rings.
Greg
Old 02-01-2017, 02:52 AM
Daim's Avatar
All to be done. I'm just looking at some little projects to do when I finally take my XJ-S to the bodyshop. Don't know how long that would take so a few things to do in the meanwhile won't go a miss...
Old 02-02-2017, 08:37 PM
warrjon's Avatar
Yes that'll happen when the AC recharge the system.
