Harmonic Balancer / Crankshaft Damper Squealing
Nope.
GENERALLY the rubberised pulley section of that damper ONLY drives the belt/s.
The V12 drives the alternator belt ONLY, on the 5.3 that is.
The timing wheel is always bolted to the centre hard mounted section of that damper asembly.
I would think the pulley slipping is causing a no charge from the alternator, and the battery simply cannot keep up with these juice hungry cars.
If not a no charge, then an erratic charge rate, which also upsets "Her Magesty" somewhat.
arthurbennett1 (11-28-2014)
Like grant said, it isn't going to throw off the sync, because that belt slipping and the dampener being worn out still doesn't allow any movement in the timing chain. If the alternator belt is slipping that could be the cause though.
All of my XJS alternator issues have been with the voltage regulator and alternator pulley eating belts.
I concur! No danger for the timing. But I saw the voltage drop quite a bit (at idle) intermittently, with the delaminated pulley of my VDP's AJ16. I even swapped alternators with the XJ6's AJ16, only to see the same effect. It was worse with lights on (load). It was also accompanied by vibration at the damper and a low pitch rumbling throughout the engine. Not nice!
Spikepaga (11-25-2014)
Did replacing the harmonic balancer solve your problems of:
1. Intermittent voltage drop
2. Intermittent vibration
Was there any (intermittent) effect, that you recall, on the RPMs, that may have been resolved as well?
I can say that the swap alternator that went into the XJ6 is perfectly fine.
The cause of this problem was a bad coil. Even though it was new, it was causing the symptoms below to pop up every 32 seconds.
Replaced the coil and everything is back to normal.
Still have to get to that harmonic balancer...
RoyLittle0
05-25-2023 02:38 AM
Woznaldo
09-26-2015 11:02 AM
