Harrison/GM A6 or Sanden SD5102 AC Compressor Replacement
Old 07-14-2015, 01:18 AM
malc4d's Avatar
It might be easer to take it to an A/c expert to get it done, working and a guarantee . . .
Old 07-14-2015, 04:09 AM
baxtor's Avatar
Received 1,162 Likes on 751 Posts
Originally Posted by JTsmks
There are no current "drop in" replacements for R12, people love throwing that claim around, especially refrigerant manufactures! Read 11 on the link.
EPA 609 Certification - FAQ
We have one down here. Hychill -30, runs lower pressure than 134 and more closely resembles r12. I am am using it with no problems to date.
The following is a quote from the manufacturer's literature.
"Use of existing charging equipment:
The equipment currently used for existing
refrigerants requires no modification or change
for charging hydrocarbon refrigerants.
Since no retrofitting is required, HyChill
refrigerants are the perfect "drop in" solution
for systems, which previously used gases
such as CFC R12, HFC R134a, HCFC
R22, R502, R11 and others."
http://archive.hychill.com.au/pdf/hcm_e.pdf
Old 07-14-2015, 11:54 AM
JTsmks's Avatar
Originally Posted by baxtor
We have one down here. Hychill -30, runs lower pressure than 134 and more closely resembles r12. I am am using it with no problems to date. The following is a quote from the manufacturer's literature. "Use of existing charging equipment: The equipment currently used for existing refrigerants requires no modification or change for charging hydrocarbon refrigerants. Since no retrofitting is required, HyChill refrigerants are the perfect "drop in" solution for systems, which previously used gases such as CFC R12, HFC R134a, HCFC R22, R502, R11 and others." http://archive.hychill.com.au/pdf/hcm_e.pdf
Hychill can be explosive AND is flammable, once again a manufacture throwing around the "drop in" phrase.
http://aussieexotics.com/forum/cars/...-35210.60.html
Old 07-14-2015, 11:57 AM
JTsmks's Avatar
People tend to think running "flammable" gas in their AC is OK since their car uses pressurized fuel or LPG.....the problem is they forget those items aren't in the cabin with them like the evaporator is!
Old 07-18-2015, 12:56 PM
Japthug's Avatar
I found that the new A6 aluminum compressor in the picture above will NEVER fit on a later facelift XJS.
The fuel rail is much lower than a pre facelift XJ-S, so the refrigerant hose interferes the fuel hose between the fuel rail.
In addition, another lighter compressor (so called S6 compressor) of which I attach the picture isn't a very good product. I bought one and it failed in half a year, claimed an exchange and it failed in 6 months later again! In the end the guarantee period is over with those 2 compressors and I have nothing now for more than $300.
Then I tried to fit the aluminum compressor above on my 92 XJS but couldn't fit.
I am wondering what to choose next...
Old 07-21-2015, 10:23 AM
Jonathan-W's Avatar
Originally Posted by Dymaxxion
Bummer. What would it take to get R134a in my system? I've been looking all over the place but can't seem to find a straight answer. There is no refrigerant in my system currently. Something I'd like to remedy in this 90+ degree Oklahoma heat.
youtube
Published on May 28, 2013
In this tutorial He uses Dust Off as a refrigerant to charge my a/c system, the chemical you are looking for on the can is Difluoroethane cas#75-37-6
buy at walmart... can thingy on amazon and the gauges on ebay/amazon...
Old 07-21-2015, 12:42 PM
JTsmks's Avatar
OMG, I've officially seen it all now. Just stick to R134/EPA approved refrigerant. WTH is the matter with people? My XJS with R134 in it for 8 years will freeze you right out of the cabin on low in the hot FL summer (yes I'm using the stock compressor,evap,condenser). "dust off" save that for your keyboard.
  #28
Old 07-21-2015, 12:44 PM
JTsmks's Avatar
That vacuum pump he's using is good as a fishing weight...that's about it. I love the vice grips too!
Old 07-22-2015, 09:42 AM
Scoupe89's Avatar
"Hot Shot" or blends of 134a are more efiicient and cheap now compared to R12.
I have had good results with adding 1-2 lbs of refrigerant. As long as the sytem doesn't need evacuated (due to seals, physical leak).
How to Recharge the Air Conditioner in a Car: 12 Steps - wikiHow
  #30
Old 09-08-2015, 09:00 PM
TheWarlock's Avatar
Be very careful with the replacement one. It says it has Teflon, that's the number one reason the Fx15 and FS10 ford compressors suffer the "Black Death". The Teflon melts when the compressor goes south and goes through the whole system. The other problem is if one piston goes south the rest keep churning and the Teflon gets through everything. If you hear anything unusual out of that new compressor, pull the plug on it and get it out of there. Hopefully she runs long and strong for you.
Hmm, I'm in need of an ac component overhaul and I see that the retro-air unit has Teflon pistons as well:
GM/Harrison A6 Replacement Compressor | RetroAir, Inc.
So what other modern choices? I've heard of some folks using line filters, although I've never seen one. Will that circumvent this dire possibility?
Also, where are folks getting the dryer? The two kits shown on rockauto have different dryers fittings and layout compared to my S3 XJ12:
More Information for FOUR SEASONS TSN0188
More Information for FOUR SEASONS TSR1459
  #31
Old 09-09-2015, 01:22 AM
Greg in France's Avatar
Received 9,320 Likes on 5,471 Posts
Sanden are the best compressors in my experience. This thread has loads of info including a post from me giving the actual Sanden model number I have.
https://www.jaguarforums.com/forum/x...pgrade-126362/
The dryers for the pre facelift (at least, I do not know if the FL is different)) are cheap and available from the normal suppliers, eg:
Jaguar Partno_CAC1881*_RECEIVER DRIER XJ SER 3 LATE/XJS_David Manners Group with Alts
It is not a bad idea to renew the evaporator valve too, though a pain, and requires GREAT care with the cabin side of the join to be supported by a spanner (wrench to you!) to prevent the copper pipe twisting off.
Greg
TheWarlock (09-09-2015)
  #32
Old 09-09-2015, 09:05 AM
Scoupe89's Avatar
