Has anyone sourced standard 5.3L piston rings? '90 XJS
Hi Folks. Decided to do an engine /trans out on my 1990 convertible - mostly to perform cosmetic work on the engine and engine bay (including all new fuel lines and hoses - and track down a few electrical gremlins), but am looking at an engine refresh while it is out. I can source gaskets, seals, crank and rod bearings, but am having trouble finding a source for standard piston rings. Low mileage engine, but it has been sitting for a while. Cylinder cross-hatching still visible, but want to refresh while I'm this far in - virgin engine. Any leads?
Received 1,236 Likes
xjsv12 (01-28-2020)
Here are 2, only 10 more to go....
https://www.ebay.co.uk/itm/JLM1789-P...-/380840387701
Or look for Hastings part # 2C4441
https://apaengineering.net/HastingsC...partdetail/306
On an engine where you are doing a refresh rather than a full rebuild I would not use the total seal style. I've seen too many failures after using those.
https://www.welshent.com/Jaguar-53L-...rd-P11537.aspx
they are around, lots of specialists in the UK eg Rob Beere..
SearchByPartno
https://www.summitracing.com/parts/tsr-c1444
slightly overpriced
https://www.ebay.co.uk/itm/FOR-JAGUA...T/193046965618
I suggest this is a good deal.
SearchByPartno
slightly overpriced
slightly overpriced
ronbros (01-28-2020)
xjsv12 (01-30-2020)
