Have a wiring question. AB14 a Amp
Have a wiring question with the AB14 Amp
I'm re wiring the 88 xjs and I have several wires I'm not sure where they go. I have solid green, green w/white? line, smaller solid white, two white w/ blue line, and a larger gauge solid white. I'm assuming <br/>1) the larger white goes to the coils<br/>2) one of the white/blue goes to the AB14<br/>Because it's a circle connector and that's the only one I can see. <br/><br/>Does the greens go to the AB14 box?<br/>Does the smaller white go to the white/blue that is coming out of the AB14 box?
Mark
If you open up the AB14 box you will see a GM hei ignition module. Here is the wiring for it: http://www.jagweb.com/aj6eng/ce_connections.jpg
The W and G terminals go to the pickup in the distributor. If I recall correctly, the G and B spade terminals are smaller than the other two so they can't get mixed up.
Ok... I see said the blind man... I'm missing that wire, I have the plug from the distributor that goes nowhere. I'll have to see if that wire is in my trunk or I'll just have to make a new one. THANKS again!!! Just when I think I'm in over my head yall pick me up. I know I can get this old girl running again.
