Headlamp Module Rebuild DAC 6902
I would check the switch is should latch for high beam. You could test id manually at the connector from the switch. UB (Blue/Black) is the high beam wire and it is switched to ground to activate the HB.
I think the reason the parts people KNOW that they can charge $200 is because people are smashing them all of the time.
I WILL MOVE MINE but on my 1990, for now, it is just hanging out there, under the hood with like 2-3 other relays, over the driver's side wheel well, bumped, knocked - top torn off. Mine has a metal cover and I have knocked the top off, to the sound of a pretty violent spark or two, on more than one occasion. Not a nice feeling or sound. And then, with a metal cover, placing the cover back on is like a trip to the dentist for a root canal, or sumpthin, lol... I dont like it.
I would LOVE to know about a rebuild or some alternative - shoot - just a relocation makes sense for me. Pls continue!
"Pull Apart"
You mention the module pulled apart quite effortlessly. Exactly how did you do it? I gave up the idea of rebuilding my H.C.M.s a long time ago b/c they appeared to be a sealed modular unit.
btw, for other members with blinky H.C.M.s, don't you also have problems with your instrument panel lights not working .. ditto for the taillights and parking lights? The ONLY things working on my Superblue are the low-beam headlights and the passenger-side high beam light. It's my understanding that all these circuits pass through the H.C.M.. Funny thing is I had a back-up used H.C.M., and swapping them out I'm still getting the same result .. ugh!
Thanks .. question is, which relay? I lost my maintenance guide (or whatever it is called in the owner's manual set) which has the diagram of the location of all the relays. There must be one in common for the taillight/side-marker light/instrument panel lights circuits, for when that switch is activated. Not sure though how that would affect the driver's side high beam headlight not working.
Nor sure what year your car is, but see here for some electrical diagrams: JagRepair.com - Jaguar Repair Information Resource
Paul Bic (09-14-2022)
Thanks, Blade. I see now there are 4 separate fuses for the headlights (left/right and high/low). I'll check the driver's side high beam one now and I bet it turns out it is blown. If so, that problem is solved. I tried re-cleaning the relay for the taillights/side-marker lights/instrument lights) twice last night, after noticing my license plate lights were faintly glowing and the door warning chime going off w/o the key in. That fixed that problem and they are all working again.
#28
Joining this conversation as I am also having trouble with my module.
I have re-soldered the PCB connections with some improvement. Currently, the high beams remain on at all times until I switch on the headlights to the second position (fully on). When I switch to parking lights or "off" the high beams will light. When I switch off the car, the high beams relay remains activated and the high beams will drain the battery. So the relays are working, but something is not right. AND, I have switched the module with a known good one from a club member's equivalent car. His does not activate the high beams. So we know it is in the module...
#30
#31
Hi all I only had my 1995 4lt AJ16 for 2 years and I am gradually sorting out its problems
One being the headlamp control unit I have also written a few notes about how to best do the soldering job someone spoke about replacing the components and this is possible but from my experience is not required but unfortunately there is an Integrated circuit that I have not managed to identify so just wondering if there are any updates to the problems people are having with their headlights Paul south Coast UK
FS[Western US]: Parting out 1997 XK8 convertible
BobRoy
49
09-18-2016 10:48 AM
WTB[Western US]: Left Rear Bumper Over Rider for MK2
tedwone
04-06-2016 01:47 PM
DanielSWE
03-28-2016 06:22 AM
