Headlamp Washer Jet and Cover - Mission Impossible?
I have been hunting high and low for the following parts to no avail. Does anyone have suggestions on where I might find them? Were these headlamp washers fitted on any other Jags? Failing that does anyone have experience fabricating RH Jet cover from the LH Jet Cover? Is there a significant difference?
Curiously, I am able to find the left hand cover in various places but nobody has anything for the right side. It was the same when I was looking for a headlight, weird?
Headlamp Jet RH LHD7052AA
Headlamp Jet LH LHC7053AA
Jet Cover RH LHC7054AA
Jet Cover LH LHC7055AA (This I can find)
Greg
Hi there,
no they were not used on range rover sorry.
Thank you and look forward to hearing from you again. David Walker salesOn 03/03/2014 09:41, rex wrote:
can you tell me please if these ford era h/light washers on the jaguar were ever used on the range rovers in the 90s
I've been on the same crusade by the grace of God I found one from a guy piecing one out in NC, however, the advice I was given in my quest from someone was to buy the replacement covers and remove the washer spray system entirely, (those parts are still available) and since most of us don't drive these cars in lousy weather, they're really not necessary, and you end up with a clean finish. Just a suggestion.
macudc (03-03-2014)
Would you happen to have the part numbers or proper names for those covers?
Arland Green (05-11-2014)
I managed to get the two covers from jagbits in the US. I am still searching for the jets but will likely take windcaper 's advice and remove the system entirely or at least disable it until the jets turn up. I too have thought abut 3d printing but don't even have a source jet to start from.
I'm pulling my 2 jets off as the plastic was getting brittle. Looking to cover the holes up. Not sure how to do this. Any ideas?
i think one jet was replaced as one is heated, and one not. Both covers have been painted body colour. The rubber gasket is decomposing.
Would like to have them for originality, but these would need some remanufacturing.
Still looking ? New 1 here. Its dac7927 may be same ..
XJS Jaguar OE RHD Near Side Chrome Washer Jet Cover | eBay
