Headlight/fog light issue
![Lightbulb](https://www.jaguarforums.com/forum/images/icons/icon3.gif)
Here are the symptoms:
low beam headlights are very dim (much more than the usual weak light) but both illuminate.
fog lamps do not work at all
fog lamp switch will not illuminate when pressed
high beams work fine
Any assistance with a diagnosis sequence is greatly appreciated. I checked all system fuses and they are all OK,
Thank you very much.
Dave
Dave
I suspect you have more than one problem. What year is your car? The later models had a small pilot light in the headlight assembly. If your main lights are burnt out, you will only see the smal light.
As far as the fog lights, check the fuse and the relay. The relay is under the hood and the terminals do get dirty.
99xk8guy
06-05-2023 06:28 AM
