Headlights on but no beams 96 XJS
Brewtech:
You’re right, and I get that the module is very problematic. I had to open & reflow the solder on mine as well.
I simply meant that cleaning the fuses and the tension contacts in the fuse block may help.
Even after redoing the module, mine didn’t have the left main beam until after I cleaned up all the high / dipped beam fuse points in that fuse box.
Fireflights (04-07-2023)
