Heater problem.
dickc (09-20-2015)
Received 10,871 Likes
Lots of 'could be' possibilities
Heater valve stuck closed, as mentioned
Clogged heater core, or air pocket in heater core
Internal flaps not rotating to direct air thru the heater core
When you ask for maximum heat with the temp control knob does the system respond by directing air flow to the lower vents? it should, and it would indicate that the system at least understands the request for heat and is trying to comply.
When you select defrost do you get hot air from the windshield vents? If you can get hot air via this method then you know the heater valve and heater core are OK
dickc (09-20-2015)
just a point of note
the heater valve is normally open with no vac , and the vac operates it for cooling
easy to test
turn on the engine, and set the car to cooling , then pull off the small vac pipe from the top of the valve, the valve should move while pulling on and off the vac pipe
BB
easy to test
BB
dickc (09-21-2015)
I'd put my money on the heater valve. Located on the firewall inside the engine bay. A good way to check is to warm the engine, remove the front LH side of the console and check the pipes for temperature, if they are cold then it's definitely the heater valve.
These can be replaced with a GM or Ford unit as long as it is NO with no vac. I used a GM unit and it works great, it is plastic and much lighter than the original so does not need to be bolted to the firewall. Mine is held in place with the hoses and has been there for 6 years now.
dickc (09-21-2015)
dickc (09-21-2015)
jimforrest (uk)
02-28-2019 06:42 PM
