Heater valve leak
Pirk,
My Daimler Double Six 1993 had the same symptoms; sporadic coolant/water disappearance that I could not trace to any hose. Super frustrating.
It was definitely the unit/element.
Mechanic disconnected it and all has been fine. Looking to get another element/unit/valve at some point, but heating is not a big priority in Hong Kong.
Charles
Charles
I have replaced this part before. It is not uncommon to get a leaking part, brand new.
someone on this forum, I believe recommended an alternative plastic part, which I purchased later, but never installed. I will eventually install it, and will report back.
If no one chimes in with the part number, I’ll post back when I get a chance to find it.
If you’re ordering parts to Hong Kong, I’d imagine the plastic part looks to be the safer part.
