Hello! Need help with an XJS
Hi, I am new to this forum and I would like some help with my 1987 Xjs.
I need some assistance with the master brake cylinder, which as seized up. Do any other cars share the same master cylinder as the XJS?
I would also like assistance with the water pump which has seized up.
Welcome to the Forums.
Please do an Intro in thr New Members Area when the beast is sorted.
You are USA, so LHD.
Master cylinder is Jag model specific. Being a 1987 it will be Pre ABS, so simple enough. I am concerned for the rest of the system, as the seizure is probably from moisture contaminated fluid, and that will through the whole system.
I will assume you have a V12? The water pump is also simple enough, very time consuming, and a lot of "while I am in here" items that will need attention.
The Sponsors that support this site will have options, give them a try.
Art
07-13-2014 02:02 PM
