HELP: 1996 XJS 4.0L - No start after engine wash
Old 06-13-2021, 07:03 PM
Armani Kaiser's Avatar
I swapped the MAF out for a tried and tested one from my other XJS. I also tested the voltage from the MAF harness and they're all reading correct so I dont suspect that is at fault. I've got thr harness for the crankshaft sensor out and drying incase there is any moisture, I will also clean it before plugging it back together. The coils are out and drying just incase they saw any moisture, however they were all bone dry as I pulled them out.
Old 06-13-2021, 09:18 PM
Spikepaga's Avatar
Originally Posted by Armani Kaiser
It started for a moment!
I went to go and recconenct the batteries and uplug the coils and I thought I would just quickly try and start it before pulling the coils and it started straight up! It revved at about 1500rpm for about 30 seconds and then as it dropped down to 600 it cut out and I'm back to a crank and no start situation.
Does it ellude to an intermittent sensor, or perhaps it is just drying out? Either way it's great to hear it going again for a brief moment!
Also quick tip, over cleaner will do a brilliant job to get all of that pesky brake dust off the rear of your rims!
I am starting to think this has to do with possibly turning the car on and of to move it versus the water bath , which is still not advisable; but it seems like the car is flooded. If she catches again give her gas until she remains on.
Old 06-13-2021, 09:23 PM
It does seem to follow that it could be flooded. I've been gassing it as much as I can within reason, generally not letting it go beyond 3000rpm. I'll keep trying though, would hate to rev a cold engine too much and cause some damage!
Old 01-24-2022, 01:58 PM
rlh6805's Avatar
Hi, I don't know why but for some reason I decided to log into my account on the forums here and saw this. For my 96, the no start after wash issue was caused by water running down the ECU wires and into the ECU connectors. The ECU is in the passenger side foot well. Water from me washing it followed the harness through the bulkhead and got into the ECU connectors. If I remember correctly, I disconnected the battery, and pulled the connectors to the ECU. Dried up the harness side connector cavities. I then took the ECU to my bench and opened it up and dried it out. I let it sit for a few days to make sure it was completely dry before connecting the ECU back up to the harness in the vehicle. It started right back up with no issues.
MattVo29
09-03-2022 09:32 AM
Oliver Hopkins
11-02-2019 08:31 AM
El Gato
03-06-2016 10:43 AM
nick128
10-27-2015 12:24 PM
wind blown xjs
05-20-2014 12:14 PM
Quick Reply: HELP: 1996 XJS 4.0L - No start after engine wash
