Help!! AC Evaporator needed
I've never seen an aftermarket one. It's a huge amount of work to get to the evaporator, are you 100% sure you need to replace it? What happened?
You can get one here: https://www.jaguarclassicparts.com/u...ing-evaporator
You are 100% right. Dash has to come out. Yes refrigerant leaking out condensate drain from evaporator. Already replaced ALL other AC parts. At a cost of $1000.00 and now being quoted $2200.00 for evaporator which is only available through Jaguar ($900.00) and the additional $1200.00 is for labor to replace it. I am curious though could it be leaking at "O" rings or be repaired?
It's possible, I suppose that it could be O rings, or a faulty expansion valve. The expansion valve can be tricky to remove, it is easy to crack the evaporator if you don't do it right and support the evaporator pipe with a wrench. In theory, an evaporator could be braized/welded ( they are aluminium), but it is a pressure vessel ( the high side can approach 300 psi), so it would have to be very good welding. If you're going to all the work to remove it, I'd put a new one in if it was me.
At the moment, £543 from Jaguar in the UK works out to about $660 USD, plus probably another £40 for shipping, you should be able to order one for less than $900. Jaguar Classic uses DHL, you'd have it in 2 days.
Greg in France (08-06-2019)
Failure of the evaporator seems to be quite rare, so a good used one should also work.
https://www.justjagsuk.com/products/...ntilation-6340
He should just google and look about a bit, I reckon.
