HELP! Appears that both the block heater and electric fan are stuck on.
What I meant was if the relay has failed in the òn position, pulling the relay from the socket won`t determine if the relay is good or not. The thermal switch is supposed to close at 85C, so if the temperature is below that it should be open circuit.An ohm meter across the terminals should show infinite resistance below 85C.
radiodjkev
03-11-2013 05:47 AM
denraden1
01-05-2013 01:52 PM
