Help finding wire 95 v12 ECU Harness
I am trying to find a source for the lower wire in the picture. I think it is an 2/18 copper braid shielded wire. Any clues? The only place I found something like it will only sell it in 100ft lengths.
http://www.awcwire.com/part.aspx?partname=stj-18/2
The location I need this for is the harness that runs from the passenger footwell ECU to the 2 front ignition amplifiers.
It's an extremely complex harness which looks like it has seen several attempts by the PO to fix.
Any advice you might provide is sincerely appreciated.
will this work?
http://www.waytekwire.com/item/ST18-...AY-PVC-JACKET/
That STJ stuff is made for 400 plus degrees and is over 3 bucks a foot
According to the specs, its good for up to 176 degree f. I can only imagine that oil temp on these cars is over 300. I have read articles that say the oil temps are part of the heat problem with the V12s. The heat from the oil, adds to the heat of the coolant. I would imagine that with the hood closed, idling in hot traffic, one might see over 250 degree F. So, I would be a little cautious on a wire rated to 176.
Dicque
09-19-2015 12:53 PM
jagent
09-12-2015 01:40 AM
