HELP! I may have screwed up the threading on fuel pressure sensor!
I finally got my old Fuel Pressure Switch off, LHD5642AA. It was on there tight! Turns out I needed a 12mm crowsfoot, even though the new one needs an 11mm to put it back on.
When I finally broke it loose, the threads on the old sensor were messed up. I couldn't thread the new sensor on, so I checked it out and it seems that I needed a 10mm-1.00 tap to fix the thread...
I may have taken it too far. When reinstalling the new sensor, I kept tightening until I snapped the head off of the new sensor, Basically the crowsfoot leveraged the head off while I was tightening the sensor back on.
I ended up removing the broken sensor and am prepared to order a new one, however, did I really botch this up? Did I clear out a tapered female thread in the engine? Does anyone know what the threads are supposed to be? I see 1/8-27 NPT on line, but that can't be right, that's not even close to a 10mm-1.00....right?
pitch.
l assume you mean the oil pressure NOT fuel pressure. You may need to source a replacement "spider" and start again.
I tried searching for EBC3515 at JDHT and came up with nothing.
The threads seem close enough that i was able to screw in the part, before I took it too far and broke it. Is it worthwhile to wrap some Teflon plumbers tape around it and give it a go? I just need to be careful to not push it too far.
orangeblossom
11-13-2017 10:43 AM
1964Daimler
09-09-2015 04:50 PM
hilaryv215
09-15-2014 07:51 AM
