The shorter hose goes from the air cleaner to the AAV. The longer hose was supposed to replace it, but is clearly the wrong part. Does anyone know what the correct part number is? I tried the usual part suppliers but the long hose is the only hose I see listed for this application.
Failing that, does anyone have any ideas of how I can repair the original hose? I eased its release with a utility knife before I discovered its unavailability. Its got a nice smooth cut about 3/4" long. I tried grey silicone already, it didn't hold. Maybe black?
This is the fix I did for a friend. First cut a normal 90 degree silicone hose to the right shape to replace he OEM one you cut. Then insert one of these for the take-off to the distributor ventilation. https://www.viperperformance.co.uk/h...one-hoses.html
