Help, key trouble.
1996 XJS 4.0 keys seem to only work when they feel like it. I paid $55 last week to get it unlocked. I had left a new key(I got this from Jag dealer 2 weeks ago) in the ignition and locked it with the old key. Locksmith in Richmond tested both keys and said there no chips in either. I drove it home and had my love lock me inside. Outside key worked fine then. The trunk key refused to unlock yesterday with no key in the ignition and the doors unlocked.
Is this a common problem with these cars? I will just have to leave all unlocked unless I can get this problem sorted out. I don't have a remote for it and the Dealer said he didn't believe they were still available for this car. Probably would be very expensive. I prefer to lock it manually anyway. Not too fond of fobs. Thanks for any help.
Bobby
Bobby
@RagJag
I read and re-read your post a few times but I can't quite work out what's not working in your situation ?
After looking at the circuit diagrams, I'm also pretty sure there is no chip or immobilizer in even the 96 last of the line keys, and I'm also not aware of a scenario where the doors won't allow you to unlock them if there is a key in the ignition. In fact the door locking circuit is not connected to anything to do with the ignition circuit
When you say the key won't work do you mean it won't turn in the lock, or it turns but doesn't open any doors ? or it turns and only unlocks the driver door ? (or whatever door it's in)
If you manually lock and unlock the car from the inside by pushing the locking lever on the door forwards and backwards, what happens? does the other door and the trunk lock and unlock ?
There is also a further complication where you can "set" the trunk NOT to open when the doors are unlocked. This is accomplished by putting the key in the trunk and turning it a certain way then closing the trunk. (I can't quite remember now)
FWIW, I had weird issues with my key locks and I fitted a remote system. Your 96 car has the huge advantage of being prewired for a security system, so there is a big multiplug in the trunk, underneath where the aerial is that you can connect a simple aftermarket remote locking system to very easily......
Post back some more details on whats working and not working and we can go from there
@ Greg Edge
We were typing at the same time. Great minds and all that :-)
@ Greg Edge
Greg and Sarc, Very glad to know the locks and ignition aren't connected. The keys will not turn in the lock. Drivers door is counter clockwise to unlock. Odd thing is this is an intermittent problem. The little paddle lock handles both work fine so the electrics are okay.
I may get an aftermarket remote if you think that will work. What kind and where?
Also thank you for the help.
RagJag
RagJag
I have this fitted to 3 cars..... no problems and pretty cheap
Great. I'm sure you already have the circuit diagrams.....
http://www.captainjaguarscathouse.co...ec%20Guide.pdf
Fig 28 is the security system.
The bulldog system can drive lots of different door lock types.... the XJS has "Type B (-) negative" door locks, so you follow that diagram in the instructions. You can also connect the interior lights to the bulldog so when you unlock the car, the interior lights come one for a short time, which is quite handy. Again, it's easy because there is a wire for this already in the vacant security plug.
Let us know how you get on
Hello!!
I would personally try to get the original security system working. The remotes are all over e-bay and can be programmed quite easily if you follow a few steps. I have the same car you do (its even BRG!!) and I have programmed three OEM remotes. It can be a bit tricky at first but definately do-able. I try to avoid using after-market products on these cars except for electric fans and the like.
Good luck!!
Good luck!!
Sarc & Spikepaga, There is a box in the trunk, Part #DPP 1050/06
There is a fuse box with about 12 fuses, all in good condition. There is alarge white plug also with what I take to be a jumper plugged into it with a red/blue wire The wire has a number tag with #26. Hope that is clear.
Bobby
Bobby
Bobby
Bobby
Dpp 1050 is the security module. You should be able to program a OEM remote to your car.
Sarc, my hat is of to you. I have my remote system and it is quite a chore to install. The instructions are not at all clear and in very fine print. I may not even attempt it. Bulldog has installation available, however I imagine that would be costly. I think I may buy an OEM remote and program that as a first choice. I see thay are not prohibitively expensive.
Bobby
Bobby
philwarner
28
07-11-2017 10:21 AM
Jzar
09-27-2015 02:55 PM
