Help please with Teves III connector(s) info
I have read through the dozens of posts and pages of archives, and I still need some.
I need to know exactly how to test the '90 XJ-S ABS valve block
solenoids. I know to apply 12VDC to each of the solenoid
contacts in the valve block connector, but I do not know
which way the connector tabs are numbered (and I am not going
to make any assumptions, after all, it is a Jaguar).
So, is PIN 1 on the left or the right when looking at the
connector? I also need the same information for the ABS ECU
connector and any tips that may be applicable. All replies
greatly appreciated.
Thanks in advance, and yes I am a newbie.
This should solve your problem:
RennsportKC ? Jaguar XJS ATE ABS repair?
https://www.jaguarforums.com/forum/x...photos-140828/
Hello OB. Thanks, I appreciate your. Actually, I had found and copied ALL of your thread about repairing the actuator/master a week ago (it is 45 pages in a MS Word document) and found it MOST helpful. i think my problem is that i have done so much research that i have confused myself.
Your other link, to the RennsportKC blog, was also very helpful as it showed me which terminal to connect my VOM negative to. Thanks. i will let you know what I find out.
orangeblossom (06-06-2015)
I am going to add that RennsportKC blog to my own Post, so that its altogether, in case anyone else gets a problem.
