Help - removing fuel filler neck
Had some time to get started with removing my fuel tank today. All was going ok with the one thing left being the fuel fill pipe - How on earth do you remove this? It wiggles about but I just cannot pull it free out of the tank. It doesn't help that I parked that side of the car next to a wall so can't walk round but still.
The rubber flexible pipe which goes between the tank & fill cap came loose ok & rotates, I just can't remove the pipe!
Is there a special trick? Does it unscrew?
Remove all the grommets tighten a jubilee clip around the neck and use a 3 legged oil filter wrench on it, the sort that tightens as you turn it .getting it back in is a different matter
New High Quality Oil Filter Wrench 3 Leg Oil Filter Remover Tool Drive HT | eBay
Depend witch way you turn it. Look at the jdht part website
As I previously posted. Thats how you get it out.it is just a tite fit
click on this link
https://www.jaguarforums.com/forum/x...r-hose-163693/
click on this link
Asdrewq (06-17-2016)
