Help - Steering Wheel....
Bit difficult to say. Jaguar went to the Airbag wheel and changed the steering column in 1990. I am assuming you do not have airbag wheel if you are replacing it, so I would say that most likely it will work. As far as I know the column was the same until changed to the height adjustable. I do not know if the mount is the same.
the later 1989 MY onwards car had a different auto indicator cancelling system , basically a peg on the back of the steering wheel that activated it , as well as the mild facelift steering column surround and indicator stalks ,
so the momo kit will not auto cancelled the indicators, and the airbag would need to be ' altered'
BB
BB
