Help won't start
Old 01-18-2021, 03:25 PM
Cruizer67's Avatar
Originally Posted by ptjs1
Cruizer67,
I would try a couple of easy things:
- Immediately after a full run when the car has been completely warmed up, I would immediately pull all 6 spark plugs and see if you've got any differences between them which may indicate an igniition fault or injector fault on one or more cylinders
- as you've got a smell of gas plus difficulty starting and misfiring even when warm, I would try starting the car, getting it slightly warm so it won't stall and then disconnecting the coolant temperature sensor and see what happens. The sensor enables enrichment to aid starting and warm-up. If it's failing, it could be causing any of the symptoms that you describe.
Good luck
Paul
Thank you Paul for the suggestion i will definitely try these steps
  #42
Old 01-18-2021, 04:06 PM
orangeblossom's Avatar
Received 3,812 Likes on 2,639 Posts
Hi Bernard
To add to that excellent suggestion from Paul (ptjs) you can Bridge the Wires on the Coolant Temperature Socket, to fool the ECU into thinking that the Injectors are over fuelling and cutting down on the supply, in what is known as 'The Paper Clip Trick'
'The Paper Clip Trick' to Test to see if the Coolant Temperature Sensor is working ok
The following 2 users liked this post by orangeblossom:
Greg in France (01-19-2021), ptjs1 (01-18-2021)
Trey Bell
XJ XJ12 ( X305 )
02-22-2020 02:11 AM
Doug-Vegas
01-08-2020 04:26 PM
Xjr400hp
General Tech Help
03-30-2017 11:03 AM
1arrowdown
08-30-2014 10:05 PM
Ebasuc
06-16-2014 08:12 AM
Quick Reply: Help won't start
