High Beams problems
I easily opened up the module tonight and it looks brand new inside. Both relays do work. I checked the resistors and they too are fine. I could not check the diodes or capacitor--although the capacitor did not seem to have any leaks. I did check using a meter for cold solders. That is, I checked for continuity from the solder to the part that was soldered. All seemed fine there. Does this method work that I used?
I am having my doubts that this module is bad.
Jomo
