High Idle After Throttle Adjustment
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
This is a US-Market 88 Hess XJS V12 for reference.
My XJS, ever since I got it running again, has had a bit of a rich idle and it's not perfectly smooth, can be a bit "lumpy" at times. I found that the CTS was bad, replaced it, helped massively. I also found that my original TPS was throwing pretty erratic readings anywhere other than at idle position and full throttle, so I replaced it with the Mustang sensor that many people on the forum have also done, also helped massively. The car up until today basically was running pretty good, but the idle wasn't as smooth as I think it should be and it still seemed to be running slightly rich.
Which brings me to today: I decided I should have a look at the throttle linkages and see if they've come out of adjustment since the car left the factory, since I assume/assumed they've never been touched before. I used the adjustment procedure PDF and properly gapped the butterflies and set the set screw where it should be. Before I adjusted them, the butterflies were pretty much adjusted all the way in to where I couldn't even drag my thinnest feeler gauge between the bore and butterfly. After adjusting both sides to the specified gap, double checking, and adjusting the throttle rods so there'd be less slop, I started the car and the idle is now super high... about 1950 when cold and drops to about 1500 after running for a couple of minutes.
Now, this could be a byproduct of the increased RPMs, but the car doesn't seem to idle nearly as rich and does seem smoother. This got me thinking, is it possible that the AAV is stuck and the previous owner just adjusted the set screws all the way in to lower idle RPMs? Or maybe I'm just adjusting it wrong somehow. Sidenote, would an idle TPS voltage of 0.44 cause such a high idle? That's what the replacement Mustang sensor reads at idle, which I know is slightly above what the factory sensor should be.
Received 10,871 Likes
Remove the LH air filter cover. You'll see the air inlet to he AAV. About 1" diameter. Block it of with your thumb (or whatever). Does the idle drop down? If so, bingo.
(Don't be tempted to permanently block the inlet!)
The following 3 users liked this post by Doug:
Following on from Doug.
Someone has masked an AAV issue, closing the discs is a classic give away.
Make sure you have a NEW 90deg hose elbow for the top of that AVV before you start, they split without touching them, and thus ruin your day 100%.
These attachments should clear the mud a tad.
The following 3 users liked this post by Grant Francis:
The following 2 users liked this post by Greg in France:
BuckleSpring (07-05-2021),
Grant Francis (07-05-2021)
I've used the Mustang TPS and, yes, the idle reading is a bit high. This never caused a high idle or any other tangible problems. It ain't right to have the voltage that high (as you know) but the engine will perform OK as far as seat-of-the-pants goes.
BuckleSpring (07-06-2021),
Doug (07-06-2021)
You could leave the inlet plugged-off if you found a different source for the distributor vent system
or adjusting the throttle back to where it was, just for the time being?
Is the 90deg elbow on top of the AAV a generic part I could get locally, or do you have a link to one available here in the states? I figure if someone came up with the mustang sensor idea, wouldn't surprise me if someone found out that hose was the same as a 19XX Chevy Whatever.
Grant Francis (07-06-2021)
In my experience the V12 doesn't need an AAV at all.
My previous V12, years ago, had a dead AAV. Fortunately it died in the closed position so I didn't have a too-high hot idle. Anyhow, I had no cold running problems until or unless the ambient temps neared freezing. Start the engine cold and it idles perfectly at 600 RPM, drop the car in gear, drive away. If the conditions were really cold a bit of nursing with the throttle was needed for a few moments before the engine would idle on its own.
On my present V12 I ditched the AAV entirely and never looked back. Same result; no cold idle problems. If the temps get near freezing I use the foot operated AAV, the one hanging next to the brake pedal
I've rebuilt a couple AAVs. They never worked for long. Maybe I flubbed-up...always a distinct possibility
Later I'll take a pic of my idle adjust system and post it.
The following 2 users liked this post by Doug:
The following 3 users liked this post by Greg in France:
As a temporary solution I'll just 3d print a cap for the AAV inlet and plug the line that went to the distributor. I'll order a new PCV and AAV elbow this weekend as well, since both are very cracked, maybe see about rebuilding the AAV before disabling it in some capacity. I sprayed some penetrating fluid into the inlet in the hopes it might free up, no luck on that yet.
