high performance engine bearings
so the crank has been cut. stroked out to 74.5mm and the mains had to be taken 10 under.
does amyone know of any company that makes high performance main bearings?
I want the car to be bulletproof and handle high rpms. my end goal is 600+hp and 7700rpm. but that is further down the line.
I think I will be catching up with him next weekend so I will ask what he did. If you can modify to use off the shelf parts it will most likely end up costing less in long run.
