High tension lead routing
Old 04-04-2018, 12:37 AM
Alan Lindsay's Avatar
Default High tension lead routing
Hi all,
Im wading through a major engine clean up on a very sad and neglected XJ12 engine
Good news is that on lifting the cam cover, inside the engine looks immaculate.
The high tension leads seem to be very messy looking more like a plate of spaghetti than engine components
Is there a correct routing diagram of the spark plug leads to be as neat and functional as possible.
Regards
Al
Old 04-04-2018, 01:08 AM
baxtor's Avatar
Received 1,165 Likes on 754 Posts
Originally Posted by Alan Lindsay
Hi all,
Regards
Al
Memory no longer allows me to say where, but i have seen routing diagrams in jaguar manuals so they do exist. "spark plug wire routing" on google resulted in several useful hits.
Old 04-04-2018, 02:33 AM
Greg in France's Avatar
Received 9,371 Likes on 5,493 Posts
OEM the wires are mainly very long, because they have to get round the cruise bellows. As I have removed the cruise, I measured up more exactly what would be required, and ordered them up from a UK specialist. Just in case it is useful, attached is the lengths required, and the end-type that goes best.
File Type: pdf
The following 2 users liked this post by Greg in France:
Alan Lindsay (04-04-2018), Grant Francis (04-04-2018)
Old 04-04-2018, 03:59 AM
Some Day, Some Day's Avatar
Received 1,049 Likes on 668 Posts
Here's what I believe should be the proper routing, though there might be some model year variance:
Old 04-04-2018, 04:31 AM
leo_denmark's Avatar
I have mounted a set of Magnecor leads. It still looks quite messy as the wires is crossing over the distributor cap, and the blue leads does nothing to hide this...
My car has the Lucas Digital P as used appr. 1981-1989, so if you have the same you can see my description of the task here:
LINK to xj-s.dk
Old 04-04-2018, 09:54 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
CAREFUL! That routing only applies to 88.5-96 XJ-S/XJS. The Series III XJ12 has the Lucas standard setup. The XJ81 XJ12 has the more sophisticated distributorless ignition system.
leo_denmark
05-20-2016 05:03 AM
Lifts
10-08-2012 08:50 PM
2000CAXK8
01-09-2011 03:28 AM
chazaroo
06-13-2009 01:40 PM
Quick Reply: High tension lead routing
