Hooked up new battery and having a constant beep?
Disconnect the battery wait re-connect at each beep (should be 5) press the remote. if more than 1 remote use each one once then press 1 until beep stops
Or you could use the search function ...................................Just saying
https://www.jaguarforums.com/forum/s...archid=3380792
It helps if you put the year and type of car in your txt. Also Yankland is very big....a State or city helps people offer local help.............
CaneCounsel007
11-13-2015 09:05 PM
